Knowledge Base Article
Does an Intel® Quartus® Programmer examined Programmer Object File (.pof) include the EPCQ non-volatile configuration register (NVCR) value?
Description
No. When the Intel® Quartus® Programmer examines the EPCQ/EPCQ-L/EPCQA configuration devices, it doesn't read the non-volatile configuration registers (NVCR). So the examined programmer object file (.pof) doesn't have the NVCR values.
If you program a configuration device with such .pof, the Quartus Programmer will use the value read from the current configuration device.
Updated 3 months ago
Version 3.0
