Knowledge Base Article
Does Altera support the PLE3-12A Programmer?
Description
The PLE3-12A Programmer is obsolete and is no longer supported by MAX PLUS® II software. You can use the Master Programming Unit (MPU) with the appropriate adapters to program Altera® devices.
Adapters with the prefix "PLE" require the PLAD3-12 adapter when used with the MPU; adapters with the prefix "PLM" can be used directly with the MPU.
For a complete listing of available new programming adapters, go to Altera Programming Tools.
For additional information on programming hardware, refer to the Altera Programming Hardware Data Sheet (PDF).
Updated 1 month ago
Version 2.0
