Knowledge Base Article
Does a Raw Programming Data File (.rpd) contain a checksum?
Description
No, a .rpd file is raw programming data files for EPCS and EPCQ devices, so it will not contain a checksum.
If a checksum is required you will need to generate one yourself using a Cyclical Redundancy Check algorithm.
Updated 1 month ago
