Knowledge Base Article
Do the SerialLite II Design Examples on altera.com support VHDL?
Description
The design examples for SerialLite II  IP core on altera.com (http://www.altera.com/support/examples/interfaces-peripherals/exm-seriallite-stratix-v.html) are supported for verilog simulation only. You may encounter issues if you simulate the design examples in VHDL.
Resolution
No work around is provided. You must create your own VHDL simulation by referring to the existing Verilog HDL design examples on altera.com.
Updated 2 months ago
Version 2.0
