Knowledge Base Article
Do I need to set the TD bit in the first dword of the PCI Express TLP header to generate and forward ECRC?
Description
The PCI Express® Hard IP core requires that the Application Layer set the TD bit for each transmitted TLP header.Resolution
Ensure that the TD bit of the TLP header is set by the Application Layer when ECRC generation and forwarding are enabled.Updated 2 months ago
