Knowledge Base Article
Do I have to drive both ports of a differential a pin in gate level simulation netlists or do I need to provide a true differential input?
Description
If your top level design in the Quartus® II software instances Altera differential IO buffers or uses IP blocks with top level differential inputs ( p and n ports at the top level) your external logic must drive a true differential signal into the Quartus II generated netlist.
If an Altera Differential IO buffer model sees an unbalanced input it will drive X onto the output.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
