Knowledge Base Article
Do dedicated clock input pins on Banks 3A/8A and Banks 3B/8B support single-ended I/O standards for Cyclone IV device?
Description
Yes, dedicated clock input pins (CLKIN) on Banks 3A/8A and Banks 3B/8B support single-ended I/O standard for Cyclone® IV GX devices when the clock is not used as a transceiver input.
If the CLKIN on Banks 3A/8A and Banks 3B/8B is used as a transceiver REFCLK, the CLKIN only supports differential I/O standards and VCC_CLKIN on the Bank must be set to 2.5 V.
If CLKIN on Banks 3A/8A and Banks 3B/8B is used as a non-transceiver PLL REFCLK, it can support single-ended I/O standards. For CLKIN on Banks 3B/8B, only positive terminal inputs support single-ended I/O standards.
Updated 3 months ago
