Knowledge Base Article
DisplayPort Sink General Register Bit Corrupted for RX Maximum Lane Counts Less Than 4
Description
The DisplayPort sink general register address 0x0001 (DPRX_RX_STATUS) corrupts when you configure the RX maximum lane count (RX_MAX_LANE_COUNT) to 2 or 1.
DPRX_RX_STATUS definition:
  • Bit16: SYNC_LOSS
  • Bit7: SYM_LOCK Lane3
  • Bit6: SYM_LOCK Lane2
  • Bit5: SYM_LOCK Lane1
  • Bit4: SYM_LOCK Lane0
  • Bit3: CR_DONE Lane3
  • Bit2: CR_DONE Lane2
  • Bit1: CR_DONE Lane1
  • Bit0: CR_DONE Lane0
However, when you configure the RX maximum lane count to 2 or 1, the register bit definition is shifted.
This issue causes the RX core to fail link training in AUX_GPU mode because the software API fails to detect SYM_LOCK due to the shift in the bits.
Resolution
To work around this issue, set the software API to detect the shifted DPRX_RX_STATUS definition:
If RX_MAX_LANE_COUNT = 4 (follow the standard definition)
  • Bit16: SYNC_LOSS
If RX_MAX_LANE_COUNT = 2
  • Bit12: SYNC_LOSS
  • Bit3: SYM_LOCK Lane1
  • Bit2: SYM_LOCK Lane0
If RX_MAX_LANE_COUNT = 1
  • Bit10: SYNC_LOSS
  • Bit1: SYM_LOCK Lane0
This issue is fixed in version 16.0 Update 1 of the DisplayPort IP core.
Updated 1 month ago
Version 3.0
