Knowledge Base Article
DisplayPort RX Video Start of Line and Start of Frame Signals Asserted More Than 1 Clock Cycle
Description
The DisplayPort RX video start of line and start of frame signals (rx_vid_sol and rx_vid_sof) stay asserted for more than 1 clock cycle. This issue is caused by the change in the signals\' FIFO control behavior. If your video processing IP core detects the rx_vid_sol and rx_vid_sof signals\' level, it will process the video data incorrectly because these signals are misaligned. If your video processing IP core detects the rising edge of the rx_vid_sol and rx_vid_sof signals, there will be no impact on the video processing behavior.
Resolution
To work around this issue, add a rising detect logic for these two signals after the DisplayPort RX core.
This issue is fixed in version 15.1 of the DisplayPort IP core.
Updated 1 month ago
Version 2.0
