Knowledge Base Article
DisplayPort Receiver Unable to Send Correct EDID to DisplayPort Source
Description
The DisplayPort IP core receiver may not be able to transmit video from the DisplayPort source at the desired resolution. This problem is caused by the incorrect transmission of the EDID in the receiver to the DisplayPort source.
This issue affects the DisplayPort source that reads the EDID from the DisplayPort IP core to determine the supported resolution.
This issue is fixed in version 14.0 Update 1 of the DisplayPort IP core.
Updated 1 month ago
