Knowledge Base Article
DisplayPort IP Core Transmits Unexpected Last Pixel Data At the End of Every Video Line
Description
The DisplayPort TX core may transmit video with unexpected last pixel data at every end of video line for certain combination of resolution and color depth. This issue may occur when the total symbols (TS) required to transmit active pixel data per line per lane is not in multiple of SYMBOLS_PER_CLOCK (2 or 4).
This issue is caused by the flaw in the packetizer array indexing.
The total symbols required per line per lane (TS) across color depths can be calculated as:
16 bpp: TS = (active pixels per line x (4 x 1) / 2) / lane count
18 bpp: TS = (active pixels per line x (4 x 9) / 16) / lane count
20 bpp: TS = (active pixels per line x (4 x 5) / 8) / lane count
24 bpp: TS = (active pixels per line x (4 x 3) / 4) / lane count
30 bpp: TS = (active pixels per line x (4 x 15) / 16) / lane count
32 bpp: TS = (active pixels per line x (4 x 2) / 2) / lane count
36 bpp: TS = (active pixels per line x (4 x 9) / 8) / lane count
48 bpp: TS = (active pixels per line x (4 x 3) / 3) / lane count
For a resolution example of 1,368 active pixels per line, 30 bpp and lane count of 2, the total symbols required per line per lane is
1,368 x (4 x 15) / 16 / 2 = 2565
The value of 2,565 is not a multiple of 2 or 4. This means you may observe unexpected last pixel data at the end of every video line.
Resolution
There is no workaround for this issue.
This issue is fixed in version 16.0 of the DisplayPort IP core.
Updated 1 month ago
Version 2.0
