Knowledge Base Article
Design Space Explorer II compilation errors: "[Errno 99] Cannot assign requested address" and "[Errno -3] Temporary failure in name resolution"
Description
If the Design Space Explorer II fails to obtain a network IP address for your machine when running a compilation, the program may generate an [Errno 99] Cannot assign requested address or [Errno -3] Temporary failure in name resolution
message.
Resolution
To fix these errors, navigate to the <revision>.dse file and add the line host=<your IP address>.
You can use the following commands in your machine\'s command line tool to obtain your IP address: on a Windows/Linux platform, use ping <hostname>; on a Windows platform, use ipconfig; and on a Linux platform,
use /sbin/ifconfig.
If you are unable to determine your IP address and your compilation type is local, you can use host=127.0.0.1.
Updated 2 months ago
