Knowledge Base Article
Default PCIe HIP parameter differences for designs created before 12.1
Description
Some PCIe HIP parameters are set to non-optimal or incorrect values.  Three are related to PCIe HIP behavior associated with sw programmed Function Level Reset(FLR), atomic operations, and extended format header field.  The fourth parameter relates to the K-Symbol the HIP will use for deskew.  Deskewing using SKP characters will provide more tolerance to skew on PCIe lanes.
Resolution
The PCIe Stratix® V generated variant from the MegaWizard™ Plug-In Manager or Qsys system flow contains parameters which do not appear in the "Stratix V Hard IP for PCI Express" user interface.  These "hidden" parameters are set to optimum default values based on hardware characterization or transition from ES to production silicon.
The following values are recommended for use:
Values for MegaWizard Plug-In Manager:
// Retrieval info:      <generic name="deskew_comma_hwtcl" value="skp_eieos_deskw" />
// Retrieval info:      <generic name="atomic_malformed_hwtcl" value="true" />
// Retrieval info:      <generic name="extended_format_field_hwtcl" value="false" />
// Retrieval info:      <generic name="flr_capability_hwtcl" value="false" />
Values for Qsys:
  <parameter name="deskew_comma_hwtcl" value="skp_eieos_deskw" />
  <parameter name="atomic_malformed_hwtcl" value="false" />
  <parameter name="extended_format_field_hwtcl" value="true" />
  <parameter name="flr_capability_hwtcl" value="false" />
To update any of these values in a PCIe Stratix V variant generated with the MegaWizard Plug-In Manager Flow:
   1) Edit the variant(e.g. variant.v) with a text editor
   2) Locate the parameters to change in the Retrievel info section:
      For example, to set the value skp_eieos_deskw for parameter deskew_comma_hwtcl
   3) Save the variant file(e.g. variant.v)
   4) Open a qshell comment prompt and refresh the variant using the following command:
      qmegawiz -silent variant
To update any of these values in the PCIe Stratix V component in a Qsys system:
   1) Edit the variant(e.g. variant.qsys) with a text editor
   2) Locate the parameters to change in the  <module kind="altera_pcie_sv_hip_ast" section:
   3) Save the qsys file(e.g. variant.qsys)
   4) Open the qsys file with the qsys editor, then regenerate the files for synthesis and/or simulation
This is fixed Intel® Quartus® software version 13.1
Updated 3 months ago
Version 2.0
