Knowledge Base Article
DDR3 HPS Interfaces Supported Only to 450 MHz on Arria V SoC ES Devices
Description
This problem affects DDR3 products.
In Arria V SoC ES devices, the HPS hard memory controller supports DDR3 interfaces to a maximum of 450 MHz. Higher frequency interfaces are not supported.
Resolution
The workaround for this issue is to not exceed 450 MHz with a DDR3 HPS interface on Arria V SoC ES devices.
This issue will be fixed in a future release.
Updated 25 days ago
