Knowledge Base Article
DDR2 Interfaces Using Soft Memory Controller May Not Close Timing When Targeting Arria V or Cyclone V Devices
Description
This problem affects DDR2 and LPDDR2 products.
Interfaces using the soft memory controller may fail to close timing on Arria V and Cyclone V devices.
Resolution
The workaround for this issue is to use a different fitter seed.
This issue will be fixed in a future version.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
