Knowledge Base Article
DDR Controller Designs in AFI Mode with Memory Burst Length of 2 Fail in Simulation
Description
Designs that use the full-rate DDR SDRAM high-performance controller in AFI mode with a memory burst length of 2 fail to simulate.
This issue affects all designs that use DDR SDRAM high-performance controller in full-rate mode with a memory burst length of 2.
As the generated memory model does not support memory burst length of 2, your design fails to simulate.
Resolution
Use a vendor memory model instead.
This issue will not be fixed in a future version of the DDR SDRAM Controller with ALTMEMPHY IP.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
