Knowledge Base Article
Cyclone V Hard Memory Interface Does Not Provide Fitter Support
Description
The hard memory interface in Cyclone V devices does not provide fitter support. You should expect fitter errors if you attempt to compile your external memory interface IP for the hard memory interface in Cyclone V.
This issue affects all protocols targeting the hard memory interface in Cyclone V devices. This issue will be fixed in a future version.
Resolution
There is no workaround for this issue.
Updated 2 months ago
Version 2.0
