Knowledge Base Article
Cyclone IV GX CPRI IP Cores at Data Rates Above 0.6144 Gbps Have Wrong TX Transceiver Clock Connection
Description
In CPRI IP core variations that target a Cyclone IV GX device and that run at a CPRI line rate of 1.2288, 2.4576, or 3.072 Gbps, the TX transmitter reference clock input signal is connected incorrectly internally.
Resolution
To work around this issue, edit the <instance>/altera_cpri.vhd file to replace the text
pll_inclk(0) => gxbref_clk
with the replacement text
pll_inclk(0) => gxb_pll_inclk
in the following VHDL component instances:
inst_cyclone4gx_1228_s_tx
inst_cyclone4gx_2457_s_tx
inst_cyclone4gx_3072_s_tx
This issue is fixed in version 13.1 of the CPRI MegaCore function.
Updated 2 months ago
Version 2.0
