Knowledge Base Article
Cyclone® III Speed Grade Support for Full-Rate DDR2 SDRAM Memory Specification
Description
The maximum clock rate for Cyclone® III speed grades supporting full-rate DDR2 SDRAM on column I/Os are downgraded for version 9.1 and later. The maximum clock rate is downgraded because the Intel® Quartus® II tool is unable to achieve push-button placement at the faster clock rates with DDR2 SDRAM high-performance controller II (HPC II).
The table shows the downgraded specifications for the Intel® Quartus® II software version 9.1.
Full-Rate DDR2 SDRAM Support for Cyclone®III Devices
Memory StandardDeviceSpeed GradeMaximum Full-Rate Clock Rate (MHz)
Column I/O (Single Chip Select)
DDR2 SDRAM
Cyclone III
C6
167
C7
150
C8, I7, A7
150
Notes: You need 267-MHz memory component speed grade when using class I I/O standard and 333-MHz memory component speed grade when using class II I/O standard. You need a 200-MHz memory component speed grade.
This issue affects all designs that use full-rate DDR2 SDRAM with HPC II architecture and target the Cyclone III devices. If you are using DDR2 SDRAM with HPC architecture, you are not affected by this downgrade.
There is no design impact.
Resolution
To achieve higher clock rates, refer to the solution provided at:
https://www.intel.com/content/www/us/en/support/programmable/articles/000086496.html
This issue will be fixed in a future version of the DDR2 Controller with ALTMEMPHY IP.
Updated 3 months ago
Version 2.0
