Knowledge Base Article
Critical Warning(16643): Found INPUT_TERMINATION assignments found for "ref_clk" pin with multiple values. Using value: "OFF"
Description
Due to a problem with the Intel® Quartus® Prime Pro version 19.1, you may encounter the above critical warning when using the Triple-Speed Ethernet Intel® FPGA IP with LVDS I/O design when the default input termination
of LVDS reference clock is overridden by using the following QSF assignment or through the assignment editor.
set_instance_assignment -name INPUT_TERMINATION OFF -to ref_clk
Resolution
To work around this problem, remove the following line from the QIP file of the Triple-Speed Ethernet Intel® FPGA IP when there is a need to override the default input termination of the LVDS reference clock setting.
set_instance_assignment -entity "" -library "altera_lvds_core14_191" -name INPUT_TERMINATION DIFFERENTIAL -to inclock
Updated 2 months ago
Version 2.0
