Knowledge Base Article
Critical Warning: PLL <PLL name> input clock inclk[0] is not fully compensated because it is fed by a remote clock pin <Pin Location>.
Description
You might get this critical warning message in the Quartus® II software versions 10.0, 10.0sp1, 10.1, 10.1sp1, and 11.0 even when you feed a dedicated input clock pin to a PLL in Arria II GX devices.
Refer to tables 5-6 or 5-7 in Clock Networks and PLLs in Arria II Devices (PDF) for accurate dedicated input clock pin to PLL mapping. The input path to the PLL will be fully compensated if the correct clock source is selected according to these tables.
Resolution
This critical warning message has been removed in the Quartus II software version 11.0sp1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
