Knowledge Base Article
Critical Warning: Partially connected in-system debug instance "auto_signaltap_0"
Description
You may see this warning message if some SignalTap™ II Logic Analyzer signals are not connected properly in your design.
Resolution
To find out what SignalTap II Logic Analyzer signals are not connected properly, perform the following steps:
  1. Open the Compilation Report.
  2. Expand the Analysis & Synthesis section.
  3. Open the Debug settings summary section to see the SignalTap II Logic Analyzer instances in your design.
  4. Check the In-system debugging table to check which signals are not connected properly.
Updated 1 month ago
Version 2.0
