Knowledge Base Article
Critical Warning: Memory depth (**) in the design file differs from memory depth (**) in the Memory Initialization File
Description
This critical warning message is reported because the initial size of the memory is picked to be larger than necessary to be safe, so the truncation is expected.
You can ignore this warning message.
This issue will be fixed in the future version of Quartus®  II software.
Updated 1 month ago
Version 2.0
