Knowledge Base Article
Critical Warning: Fitter was unable to find Transceiver Reconfiguration Controllers associated with the following &ltnumber of transceiver blocks&gt transceiver PHY IP component blocks.
Description
Due to a problem in the Quartus® II software version 11.0 SP1, you may see this critical warning on Stratix® V transceiver devices even if the Custom PHY IP and Reconfiguration Controller IP are connected correctly.
This problem will be fixed in a future version of the Quartus II software.
Resolution
Updated 2 months ago
Version 2.0
