Knowledge Base Article
Critical Warning (332168): The following clock transfers have no clock uncertainty assignment. For more accurate results, apply clock uncertainty assignments or use the derive_clock_uncertainty command.
Description
You may see the critical warning above during the fitter stage when compiling the UniPHY-based memory controller IP.
Resolution
You may safely ignore this critical warning message.
Updated 1 month ago
