Knowledge Base Article
Critical Warning (308019): (Critical) Rule C101: Gated clock should be implemented according to the Altera standard scheme.
Description
When running the Design Assistant tool in the Quartus® II software, the following critical warning message may appear:
Critical Warning (308019): (Critical) Rule C101: Gated clock should be implemented according to the Altera standard scheme. Found 1 node(s) related to this rule.
Critical Warning (308012): Node  "<variation name>_example_if0:if0|test_rldram_example_if0_pll0:pll0|out_phyclk[0]"
Resolution
This clock is implemented in the hard logic and the warning can safely be ignored.
Updated 2 months ago
Version 2.0
