Knowledge Base Article
Critical Warning (11887): The following pin <data pin> was placed in a reserved GND location. This may cause decreased performance for HMC. Altera recommends the pin location to be grounded
Description
The following critical warning may appear after the fitter stage when an unused data pin is placed on a reserved hard memory controller (HMC) GND pin.
Resolution
This critical warning may safely be ignored without losing HMC performance.
Updated 2 months ago
