Knowledge Base Article
Critical Warning (10169): Verilog HDL warning at alt_mem_ddrx_controller.v(495): the port and data declarations for array port "afi_rrank" & "afi_wrank" do not specify the same range for each dimension
Description
You may see this critical warning when implementing a DDR2 SDRAM interface using DDR2 SDRAM High Performance Controller II with ALTMEMPHY IP version 12.0. There is a mismatch with the afi_rrank and afi_wrank port size declarations due to parameter not being passed in correctly. However, it will not affect the functionality because afi_rrank and afi_wrank are not used in the DDR2 controller.
Resolution
This problem was fixed with the Quartus II software version 12.1 and later.
Updated 24 days ago
Version 2.0
