Knowledge Base Article
Critical Warning: <slave_DDRx_instance_name>_pin_map.tcl: Failed to find PLL clock for pins mem_if|controller_phy_inst|memphy_top_inst|umemphy|uread_datapath|read_valid_predict[0].qvld_rd_address[0]
Description
You will get the warning mentioned above in Quartus® II software version 10.0SP1 and earlier if you have instantited <instance_name>_example_top.v for master and slave UniPHY controllers in your design.
pll_dqs_ena_clk signal is missing in both master and slave <instance_name>_example_top.v and this will cause the critical warning in fitter report.
To avoid the above mentioned critical warning, you should add pll_dqs_ena_clk port to the <instance_name> instantiated in the <instance_name>_example_top.v files for both master and slave module.
For example, in top level design add the port pll_dqs_ena_clk as shown below:
ddr2 mem_if (
.pll_ref_clk(pll_ref_clk),
// when PHY is the PLL/DLL master, these will be outputs that can be shared with other components of the chip
// when PHY is the PLL/DLL slave, these will be inputs from the PLL/DLL instantiations below
.pll_afi_clk (pll_afi_clk),
.pll_addr_cmd_clk (pll_addr_cmd_clk),
.pll_dqs_ena_clk (pll_dqs_ena_clk), //added
.pll_mem_clk (pll_mem_clk),
.pll_write_clk (pll_write_clk),
.pll_avl_clk (pll_avl_clk),
.pll_config_clk (pll_config_clk),
.pll_locked (pll_locked),
.dll_delayctrl (dll_delayctrl),
This issue has been fixed in Quartus II software version 10.1.
Updated 3 months ago
Version 2.0
