Knowledge Base Article
Critical Warning: *_p0_pin_map.tcl: Failed to find PLL clock for pins *:s0|*:sequencer_scc_mgr_inst|scc_state_curr.STATE_SCC_IDLE
Description
You will see this critical warning message if you compile DDR3 Controller with UniPHY with the following assignment. In this case, the Quartus® II software cannot find pll_config_clock.
set_global_assignment -name EXTRACT_VERILOG_STATE_MACHINES OFF
The Quartus II software will look for *:s0|*:sequencer_scc_mgr_inst|scc_state_curr.STATE_SCC_IDLE to search pll_config_clock.
The state will disappear if you disallow state machine generation. Thus, the Quartus® II software cannot find the clock.
Resolution
This problem has been fixed in Intel® Quartus® Prime Edition Software version 13.1.
Updated 1 month ago
Version 2.0
