Knowledge Base Article
CPRI IP Core v12.0 Autorate Negotiation VHDL Testbench File Requires Modification
Description
The compile_autorate_phy_vhdl.do file that runs the autorate negotiation VHDL testbench for a Stratix V device includes extra lines that prevent the testbench from compiling.
Resolution
To avoid this issue, in the compile_autorate_phy_vhdl.do file in your CPRI IP core installation, comment out or remove the following lines:
vcom -work xcvr_reconfig_cpri ./xcvr_reconfig_cpri_sim/alt_xcvr_reconfig/alt_xcvr_reconfig_cpu.vhd
vcom -work xcvr_reconfig_cpri ./xcvr_reconfig_cpri_sim/alt_xcvr_reconfig/alt_xcvr_reconfig_cpu_reconfig_cpu_test_bench.vhd
vcom -work xcvr_reconfig_cpri ./xcvr_reconfig_cpri_sim/alt_xcvr_reconfig/alt_xcvr_reconfig_cpu_reconfig_cpu.vhd
This issue is fixed in version 12.0 SP1 of the CPRI MegaCore function.
Updated 2 months ago
Version 2.0
