Knowledge Base Article
CPRI IP Core Dynamic Clock Switching Does Not Work Correctly
Description
CPRI IP core variations that target an Arria V, Cyclone V, or Stratix V device should support dynamic clock mode switching from master clocking mode to slave clocking mode, and from slave clocking mode to master clocking mode. However, this feature is not working correctly.
Resolution
This issue has no workaround. You must set the desired, static clocking mode at configuration time in the CPRI parameter editor with the Operation mode parameter.
This issue is fixed in version 14.0 of the CPRI MegaCore function.
Updated 2 months ago
Version 2.0
