Knowledge Base Article
Could not find start delimitter
Description
You may receive the "Could not find start delimitter" error when trying to update your EthernetBlaster or EthernetBlaster II programming cable if you unzipped the firmware_<build number>.tar.gz file you downloaded prior to updating the firmware via the EthernetBlaster or EthernetBlaster II Configuration administrative web page in your browser and then selected Upgrade Firmware and browse to the unzipped file.
Resolution
Download the EthernetBlaster Firmware Upgrade or EthernetBlaster II Firmware Upgrade file then use the file as-is. You will not need to unzip the file prior to updating.
Updated 2 months ago
Version 2.0
