Knowledge Base Article
Continuous Data Transmission from MAC Function
Description
When you switch the MAC function from half-duplex to full-duplex mode while it is transmitting data, the MAC function continuously sends data out through the MII even when you are not sending any data to the MAC function.
This issue affects variants of MAC with internal FIFO buffer operating in half-duplex mode.
Resolution
No workaround.This issue is fixed in version 11.0 of the Triple-Speed Ethernet MegaCore function.
Updated 24 days ago
