Knowledge Base Article
Configuration of pins is not enabled properly for Cyclone and Stratix Devices
Description
On the Configuration page of the Device and Pin Options dialog box, the Enable input tri-state on active configuration pins in user mode option is not enabled properly. This applies to Cyclone IV GX, Cyclone III, and Cyclone III LS.
Resolution
To enable input tri-state on active configuration pins, use the following assignment in the Quartus Settings File (.qsf):set_global_assignment -name TRI_STATE_SPI_PINS ON.
Updated 2 months ago
Version 2.0
