Knowledge Base Article
Compiler Warnings When Transceivers are Excluded From Interlaken MegaCore Function
Description
When you compile an Interlaken MegaCore function variation that excludes transceivers, the following warning message appears:
Warning: Output pins are stuck at VCC or GND Warning (13410): Pin “common_rx_c_clk” is stuck at GND
Resolution
This issue has no workaround. However, this issue has no design impact. You can ignore this warning.
This issue will be fixed in a future version of the Interlaken MegaCore function.
Updated 2 months ago
Version 2.0
