Knowledge Base Article
Compilation might result in Stratix V EDA simulation errors
Description
If you attempt to compile a design that targets a Stratix V device, compilation might fail with the following error:
Error: Unable to generate the EDA simulation netlist files because the Quartus II software does not currently support gate-level simulation for the Stratix V devices.
Resolution
Before you start a compilation, turn off the netlist writer by performing the following steps:
  1. On the Assignments menu, click Settings.
  2. In the Category list, select Simulation under EDA Tool Settings.
  3. In the Tool name box, select <None>.
To perform a nativelink RTL simulation, after compilation is completed, select your EDA tool in the Tool name box of the EDA Settings dialog box..
Updated 1 month ago
Version 2.0
