Knowledge Base Article
Compilation might fail in the ALTGX MegaWizard Plug-In Manager for Cyclone IV GX
Description
In the ALTGX MegaWizard Plug-In Manager, if you enter parameter information out of order, compilation might fail with an error similar to the following:
Error: Parameter “common_mode” of instance “transmit_pma0”
has illegal value “0.6v” assigned to it. Possible parameter values
are: “0.65V”, “TRISTATE”.
Resolution
Use the Next button to enter the settings in the correct order.
Updated 3 months ago
