Knowledge Base Article
Compilation Fails for UniPHY External Memory Interfaces if Synthesis Fileset is Mixed with Example Project Files
Description
Compilation fails if the Files list in the Settings dialog box in the Quartus II software includes files from both the example project located at <working_dir>/<variation_name>_example_design_fileset/example_project/ and the synthesis fileset located at <working_dir>/<variation_name>.
Resolution
A workaround for this issue is to perform the following steps:
  1. In an editor, open the <variation_name>_driver.sv file, located in the <working_dir>/<variation_name>_example_design_fileset/example_project/ directory
  2. In the <variation_name>_driver.sv file, change the entity name� <variation_name>_reset_sync to <variation_name>_<num>_reset_sync, where num� is the same value as in the <variation_name>_<num>_reset_sync.v filename in the <working_dir>/<variation_name>/ directory.
Updated 2 months ago
Version 2.0
