Knowledge Base Article
Clocked Video Output II Displays Control Interface When Not Needed
Description
When you configure the Clocked Video Output II IP core in Qsys, the control interface is displayed even when you do not select the Use control port option. Even though the control interface appears, the control ports do not get connected internally. It is not necessary for you to use this interface.
This issue is fixed in version 14.1 of the Clocked Video Output II IP core.
Updated 2 months ago
Version 2.0
