Knowledge Base Article
Certain VIP Suite Designs Fail to Generate In 64-bit Linux Version
Description
When you try to generate certain Video and Image Processing (VIP) Suite cores using the 64-bit Linux version of Qsys or the Quartus II software, your design fails to generate. The generated output displays multiple errors, beginning with the following error:
'Error: Invalid command name "project_new"’
Resolution
Use 32-bit Linux version of Qsys or the Quartus II software to generate the design, or use the 64-bit Windows version.
This issue is will be fixed in the next release.
Updated 2 months ago
