Knowledge Base Article
Certain Ports and Parameters Not Supported In SDI Audio IP Cores for 13.1
Description
Version 13.1 of the SDI Audio Embed and Audio Extract MegaCore functions do not support certain ports and parameters. The following ports and parameters are not fully implemented. You are not encouraged to modify the default settings
Parameter
Related Ports
SDI Audio IP Core
Include SD-SDI 24bit support
sd_edp_control
Cleanly Remove Existing Audio
strip_control, strip_status
SDI Audio Embed
Tie the sd_edp_control and strip_control input ports to 0 and ignore the strip_status port.
This issue will be fixed in the next version of the SDI Audio Embed and Audio Extract MegaCore functions.
Updated 2 months ago
Version 2.0
