Knowledge Base Article
Certain I/O Pins Should be Grounded for Cyclone V Hard Memory Controller Operation
Description
This problem affects DDR2, DDR3, and LPDDR2 products.
The Cyclone V pin-out file identifies some general I/O pins that you should connect to ground when using the hard memory interface on Cyclone V devices. If you do not ground these pins, your design might experience increased crosstalk from neighboring I/Os, or reduced maximum frequency capability.
Resolution
There is no workaround for this issue.
This issue will not be fixed.
Updated 3 months ago
