Knowledge Base Article
Center PLL in Arria V Cannot Drive Two Independent PHY Clock Networks
Description
This problem affects DDR2 and DDR3, LPDDR2, QDR II, and RLDRAM II products.
A fitter error may occur when the center PLL in Arria V devices is used to drive two independent PHY clock networks. This circumstance can occur when the PLL reference clock inputs for two memory interfaces are constrained such that they both use the center PLL.
Resolution
The workaround for this issue is to use the center PLL to drive only a single clock tree.
This issue will be fixed in a future version.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
