Knowledge Base Article
Cannot use 200G Hard IP location ehip200g_st_x1_6_rx and FGT channel location fgt_q1_ch0_rx as 200G Hard IP is currently not supported with this OPN.
Description
If your Agilex™ 7 FPGA device project uses the F-Tile E200G Hard IP transceiver path when compiling with Quartus® Prime Pro software version 23.4, you will see the error message above.
Resolution
To work around this problem, you can use the F-Tile 400G Hard IP path.
If you cannot use the F-Tile 200G Hard IP path, file an Intel® Premier Support IPS Case and provide reference number “18036390807”.
Updated 3 months ago
