Knowledge Base Article
Cannot Locate Source Code in Driver Files Shared by Multiple Projects
Description
If you hit a breakpoint in a driver file, and that driver file is shared with another project that is closed, the Nios II IDE might indicate that it cannot locate the source code.
Resolution
Open the closed system library project and resume debugging.
Updated 1 month ago
Version 2.0
