Knowledge Base Article
Can unused HPS EMIF pins be used as FPGA GPIOs?
Description
Yes, unused HPS EMIF pins can be used as FPGA GPIO's, but there are some restrictions.
The Quartus® Prime software version 15.1.1 and earlier do not check for these restrictions.  You must manually ensure that if there is an HPS EMIF in the system, the I/O banks are used exclusively as follows.
Resolution
Arria 10 SoC devices have 3 modular I/O banks to connect the HPS to an SDRAM (2K, 2J, and 2I) through a dedicated HPS EMIF.
  • Each bank has 4 I/O lanes that correspond to:
    • Lane 3: IO[47:36]
    • Lane 2: IO[35:24]
    • Lane 1: IO[23:12]
    • Lane 0: IO[11:0]
  • Lane 3 of Bank 2K is used to connect to the ECC signals of the SDRAM.
    • Unused pins in this lane can be used as FPGA inputs only, regardless of whether or not ECC is implemented in the system.
    • When there is no HPS EMIF in the system each bank can be used entirely as FPGA GPIO
  • Lanes 2, 1, and 0 of Bank 2K are used to connect to the address and command signals of the SDRAM.
    • Unused pins in these lanes can be used as FPGA inputs or outputs.
  • When using 16-bit data widths, unused pins in the 2 lanes of Bank 2J used for data can be used as inputs only. The pins in the remaining 2 lanes can be used as FPGA inputs or outputs.
  • When using 32-bit data widths, unused pins Bank 2J can be used as inputs only.
  • Bank 2I may be used to connect to Data pins [63:32] of the SDRAM.
    • If the memory is only 16 or 32 bits, these pins may be used for FPGA GPIO.
A patch is being created for the Quartus Prime software version 15.1 that will generate errors if the conditions listed above are violated.
  • The patch will be added here once released.
The patch above is also scheduled to be added to a future version of the Quartus Prime software.
Updated 2 months ago
Version 2.0
