Knowledge Base Article
Can the tx_outclock of an ALTLVDS_TX megafunction drive multiple pins?
Description
No, the tx_outclock of an ALTLVDS_TX megafunction cannot drive multiple pins in Altera FPGAs.
This is a hardware limitation.
Resolution
You can instantiate multiple ALTLVDS_TX blocks shared by the same PLL to create more output clock channels.  Use the parallel bits tied to VCC and GND to create the desired clock frequency.
Updated 3 months ago
Version 2.0
