Knowledge Base Article
Can the Quartus II software wait for a floating IP license rather than switching to OpenCore or OpenCore Plus behavior?
Description
Yes, the Quartus® II software versions 9.1 and later can be configured to wait until a floating network IP license is available if all IP licenses are in use at compilation time.
To enable this behavior in the Quartus II software versions 9.1 and later follow the steps below:
  1. Open the License Setup Page from the Tools menu.
  2. Check the Wait for floating license checkbox.
The following warning message is generated if the compilation has been paused awaiting a valid license.
Warning: All instances of floating feature <feature ID> are currently in use, waiting for one to become available.
The compilation will resume once a valid license is available.
Default behavior in the Quartus II software
If an IP license is not available and the Wait for floating license option is disabled,  a warning will be issued stating there are no licenses available:
Warning: All floating licenses for core "<IP Name>" (<IP ID>) are currently in use
If the IP block supports OpenCore or OpenCore Plus mode, the compilation will continue in OpenCore or OpenCore Plus mode. The compilation will stop with an error if OpenCore or OpenCore Plus mode is not available for the IP block or if these modes have been manually disabled for the project.
For more information on OpenCore and OpenCore Plus modes, including disabling support in the Quartus II software, please see AN 320: OpenCore Plus Evaluation of Megafunctions
Updated 23 days ago
Version 2.0
