Knowledge Base Article
Can the MMR interface be used in conjunction with the Efficiency Monitor in the External Memory Interface Intel® FPGA IP?
Description
Due to a restriction in the Intel® Quartus® Prime Edition Software, it is not possible to enable the Memory Mapped Configuration and Status Register (MMR) interface in conjunction with the Efficiency Monitor when implementing DDR3 or DDR4 interfaces using the External Memory Interface Intel FPGA IP for Intel® Arria® 10, Intel® Cyclone® 10 GX or Intel® Stratix® 10 devices.
Enabling both options will result in an error like that shown below :
Error: Interface must have an associated clock
Resolution
There is no planned fix for this restriction.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
